Datasheet Texas Instruments TMS470R1B1MPGEA — Даташит
СерияTMS470R1B1M
МодельTMS470R1B1MPGEA
16/32-битный RISC-флэш-микроконтроллер 144-LQFP
TMS470R1B1M datasheet
PDF, 542 Кб, Версия: A, Файл опубликован: 1 авг 2006
Pin144144
Package TypePGEPGE
Industry STD TermLQFPLQFP
JEDEC CodeS-PQFP-GS-PQFP-G
Package QTY6060
CarrierJEDEC TRAY (5+1)JEDEC TRAY (5+1)
МаркировкаTMS470R1B1MPGEA
Width (мм)2020
Length (мм)2020
Thickness (мм)1.41.4
Pitch (мм).5.5
Max Height (мм)1.61.6
  • Vocoder Implementation Using TMS470 High-End Timer
    PDF, 326 Кб, Файл опубликован: 8 янв 2007
    The TMS470 family of ARM7 microcontrollers contains a RISC coprocessor referred to as the High-End Timer (HET). The HET can implement complex I/O operations independent from the CPU, one of which is the capability to generate PWM signals. This application report describes using this PWM capability, along with an open source voice algorithm called Speex, to encode 8-bit voice messages without the n
  • UART Implementation Using the High-End Timer
    PDF, 120 Кб, Файл опубликован: 9 июн 2006
    This application report describes how the TMS470 high-end timer (HET) peripheral can be used to implement multiple additional full-duplex high-speed universal asynchronous receiver transmitter (UART) interfaces with interrupt capability and zero ARM7 CPU overhead. The solution is provided for both TMS470R1A256 and TMS470R1B1M devices, but the information applies to other TMS470 family members as w
  • TMS470 Expansion Bus Module Example
    PDF, 126 Кб, Файл опубликован: 20 дек 2006
    This document supplies information for using the Expansion Bus Module (EBM) on the TMS470R1B1M to interface to external memory and peripherals. The module supports the multiplexing of the input/output (I/O) functions and the expansion bus interface. When the I/O functions are not used, the EBM can be used to interface 8- or 16-bit memories.
  • Important ARM Ltd Application Notes for TI Hercules ARM Safety MCUs
    PDF, 61 Кб, Файл опубликован: 17 ноя 2011
    The purpose of this application report is to offer a convenient collection of references to application notes posted by ARM Ltd that apply to TI’s Hercules ARM Safety Microcontrollers. The document contains links directly to the ARM documents in the ARM On-Line InfoCenter as well as re-prints the ARM introduction chapter to help you better determine if you want to investigate further.
  • 3.3 V I/O Considerations for Hercules Safety MCUs (Rev. A)
    PDF, 103 Кб, Версия: A, Файл опубликован: 6 сен 2011
    As new generations of microcontrollers lower their supply voltages from 5 V to 3.3 V and beyond, issues with interfacing and noise are increasing. This application report presents cost-effective interfacing techniques for inputs and outputs of 3.3 V microprocessors in an automotive environment. In addition, concerns about 3.3 V analog-to-digital converters (ADC) are discussed.
Серия: TMS470R1B1M (2)
  • Semiconductors > Microcontrollers (MCU) > Other Microcontrollers > TMS470 ARM7TDMI®-Based Industrial MCUs
На английском языке: Datasheet Texas Instruments TMS470R1B1MPGEA
