Datasheet Texas Instruments TMS470R1B512PGET — Даташит
СерияTMS470R1B512
МодельTMS470R1B512PGET
16/32-битный RISC-флэш-микроконтроллер 144-LQFP
TMS470R1B512 datasheet
PDF, 477 Кб, Версия: A, Файл опубликован: 1 авг 2006
IC MCU 32BIT 512KB FLASH 144LQFP. ARM7® TMS470 Microcontroller IC 16/32-Bit 60MHz 512KB (512K x 8) FLASH 144-LQFP (20x20). Embedded -...
TMS470R1B512PGET
1 629 ₽
TMS470R1B512PGET
3 424 ₽
727GS
TMS470R1B512PGET
SUV System
TMS470R1B512PGET
Pin144144
Package TypePGEPGE
Industry STD TermLQFPLQFP
JEDEC CodeS-PQFP-GS-PQFP-G
Package QTY6060
CarrierJEDEC TRAY (5+1)JEDEC TRAY (5+1)
МаркировкаTMS470R1B512PGET
Width (мм)2020
Length (мм)2020
Thickness (мм)1.41.4
Pitch (мм).5.5
Max Height (мм)1.61.6
  • Important ARM Ltd Application Notes for TI Hercules ARM Safety MCUs
    PDF, 61 Кб, Файл опубликован: 17 ноя 2011
    The purpose of this application report is to offer a convenient collection of references to application notes posted by ARM Ltd that apply to TI’s Hercules ARM Safety Microcontrollers. The document contains links directly to the ARM documents in the ARM On-Line InfoCenter as well as re-prints the ARM introduction chapter to help you better determine if you want to investigate further.
  • 3.3 V I/O Considerations for Hercules Safety MCUs (Rev. A)
    PDF, 103 Кб, Версия: A, Файл опубликован: 6 сен 2011
    As new generations of microcontrollers lower their supply voltages from 5 V to 3.3 V and beyond, issues with interfacing and noise are increasing. This application report presents cost-effective interfacing techniques for inputs and outputs of 3.3 V microprocessors in an automotive environment. In addition, concerns about 3.3 V analog-to-digital converters (ADC) are discussed.
Серия: TMS470R1B512 (1)
  • TMS470R1B512PGET
  • Semiconductors > Microcontrollers (MCU) > Other Microcontrollers > TMS470 ARM7TDMI®-Based Industrial MCUs
На английском языке: Datasheet Texas Instruments TMS470R1B512PGET
