Datasheet ТI MSC1200Y2PFBT — Даташит
СерияMSC1200Y2
МодельMSC1200Y2PFBT
Datasheet Texas Instruments MSC1200Y2PFBT
ЦП 8051 с памятью 4 КБ, 24-битным АЦП, ЦАП тока и встроенным генератором 48-TQFP от -40 до 125
Precision ADC & DAC with 8051 Microcontroller and Flash Memory datasheet
PDF, 1.4 Мб, Версия: E, Файл опубликован: 18 май 2006
  • Switched-Capacitor ADC Analog Input Calculations
    PDF, 84 Кб, Файл опубликован: 1 окт 1998
    This application report describes calculations to analyze the analog input circuit to a switched-capacitor analog-to-digital converter. The calculations determine the maximum value of the external driving source resistance to provide a desired ADC conversion accuracy.
  • Thermocouple Measurements with О”ОЈ ADCs
    PDF, 265 Кб, Файл опубликован: 16 июн 2005
    Thermocouples are widely used in a range of industrial and commercial settings. Temperature/voltage responses for thermocouples are fully characterized. The small voltage output is well-suited to the high resolution capability provided by О”ОЈ (delta-sigma) analog-to-digital converters (ADCs) with a programmable gain amplifier (PGA). The specified NIST polynomials for calculating output
  • Measuring Temperature with the ADS1216, ADS1217, or ADS1218 (Rev. A)
    PDF, 67 Кб, Версия: A, Файл опубликован: 17 фев 2004
  • The Offset DAC (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 1 апр 2015
  • Amplifiers and Bits; An Introduction to Selecting Amplifiers for Data Converters (Rev. D)
    PDF, 455 Кб, Версия: D, Файл опубликован: 18 май 2015
  • Inputs Currents for High-Resolution ADCs
    PDF, 127 Кб, Файл опубликован: 6 мар 2003
  • AB-174: Getting the Full Potential from your ADC (Rev. A)
    PDF, 72 Кб, Версия: A, Файл опубликован: 28 июн 2002
    Many of today?s high-resolution ADCs (Analog-to-Digital Converters) are operating from a single supply and use fully differential inputs. This can be a problem for single-ended signals that are bipolar relative to common. This article illustrates circuit configurations that preserve the full-scale input range by using modern features, such as Programmable Gain Amplifiers (PGAs) and internal voltag
Серия: MSC1200Y2 (2)
На английском языке: Datasheet Texas Instruments MSC1200Y2PFBT
Политика конфиденциальности
