Datasheet MPC5125YVN400 - Freescale Даташит IC, MPU, 32 бит, 400 МГц, 324PBGA — Даташит
Наименование модели: MPC5125YVN400
Купить MPC5125YVN400 на РадиоЛоцман.Цены — от 805 до 6 186 ₽33 предложений от 18 поставщиков IC MCU 32BIT ROMLESS 324TEPBGA. e300 MPC51xx Microcontroller IC 32-Bit 400MHz ROMless 324-PBGA (23x23). Embedded - Microcontrollers | |||
| MPC5125YVN400R NXP | 1 679 ₽ | ||
| MPC5125YVN400R Freescale | 2 011 ₽ | ||
| MPC5125YVN400R NXP | от 6 110 ₽ | ||
| MPC5125YVN400R NXP | по запросу | ||
Производитель: Freescale
Описание: IC, MPU, 32 бит, 400 МГц, 324PBGA
Freescale Semiconductor Data Sheet: Technical Data
Document Number: MPC5125 Rev.
3, 11/2009
MPC5125
MPC5125 Microcontroller Data Sheet
The MPC5125 integrates a high performance e300 CPU core based on the Power ArchitectureTM Technology with a rich set of peripheral functions focused on communications and systems integration. Major features of the MPC5125 are as follows: · e300 Power Architecture processor core (enhanced version of the MPC603e core), operates as fast as 400 MHz Low power design Display interface unit (DIU) DDR1, DDR2, low-power mobile DDR (LPDDR), and 1.8 V/3.3 V SDR DRAM memory controllers 32 KB on-chip SRAM USB 2.0 OTG controller with ULPI interface DMA subsystem Flexible multi-function external memory bus (EMB) interface NAND flash controller (NFC) LocalPlus interface (LPC) 10/100Base Ethernet MMC/SD/SDIO card host controller (SDHC) Programmable serial controller (PSC) Inter-integrated circuit (I2C) communication interfaces Controller area network (CAN) J1850 byte
Your Electronic Engineering Resource
MPC5125 32-bit Microprocessor
General Description:
The MPC5125, a cost and power consumption optimized, automotive, industrial networking, and human-machine interface (HMI) solution. It helps reduce your development time, provides more communication peripherals at a competitive price and delivers ultra-low power without sacrificing performance.
Key Features:
- Семейство: e300
- Разрядность ядра: 32 бит
- Тактовая частота процессора: 400 МГц
- Тип корпуса: BGA
- Количество выводов: 324
- Диапазон напряжения питания: 1.33 В ... 1.47 В, 3 В ... 3.6 В
- SVHC: No SVHC (15-Dec-2010)
- Рабочий диапазон температрур: -40°C ... +125°C
- Размер ОЗУ: 32 Кб
