Datasheet MPC855TVR66D4 - Freescale Даташит ИС, 32- бит микропроцессор, 66 МГц, 357-PBGA — Даташит
Наименование модели: MPC855TVR66D4
18 предложений от 18 поставщиков
IC MPU MPC8XX 66MHZ 357BGA. MPC8xx Microprocessor IC MPC8xx 1 Core, 32-Bit 66MHz 357-PBGA (25x25). Embedded - Microprocessors
MPC855TVR66D4
Freescale
4 102 ₽
MPC855TVR66D4
11 415 ₽
Hi-Tech Circuit Group
MPC855TVR66D4
SUV System
MPC855TVR66D4
Производитель: Freescale
Описание: ИС, 32- бит микропроцессор, 66 МГц, 357-PBGA
data sheetСкачать Data Sheet
Freescale Semiconductor, Inc.
Advance Information
MPC855TTS/D Rev.
0.1, 11/2001 MPC855T Communications Controller Technical Summary
Freescale Semiconductor, Inc...
The MPC855T communications controller is a member of the MPC8xx family targeted at cost sensitive general purpose networking controller applications. The MPC855T can be used in a variety of controller applications, excelling particularly in low cost communications and networking products, such as SOHO routers, ADSL, and cable modems. The MPC855T integrates three separate processing blocks. The first two, common with all MPC8xx devices, are (1) a high-performance MPC8xx core, which is used as a general-purpose processor for application programming and (2) a RISC communications processor (CP) embedded in the communications processor module (CPM). All MPC8xx devices will have an 8-KByte dual port RAM when the MPC855T is available. The third block is a 10/100-Mbps Fast Ethernet controller with integrated FIFOs and bursting DMA
  • Семейство: PowerQUICC
  • Разрядность ядра: 32 бит
  • Размер памяти программ: 8 Кб
  • Тактовая частота процессора: 66 МГц
  • Тип корпуса: BGA
  • Количество выводов: 357
  • Диапазон напряжения питания: 3.135 В ... 3.465 В
На английском языке: Datasheet MPC855TVR66D4 - Freescale IC, 32- bit MPU, 66 MHz, 357-PBGA
