Datasheet NTE3880 - NTE Electronics Даташит IC, 8 бит MPU, 4 МГц, DIP-40 — Даташит
Наименование модели: NTE3880
![]() 7 предложений от 7 поставщиков Активная деталь, Integrated Circuit Nmos 8Bit Microprocessor 40-Lead Dip 4MHz | |||
NTE3880 NTE Electronics | 770 ₽ | ||
NTE3880 NTE Electronics | 2 624 ₽ | ||
NTE3880 NTE Electronics | по запросу | ||
NTE3880 | по запросу |
Производитель: NTE Electronics
Описание: IC, 8 бит MPU, 4 МГц, DIP-40
NTE3880 Integrated Circuit NMOS, 8Bit Microprocessor (MPU), 4MHz
Description: The NTE3880 is a third generation single chip microprocessor with unrivaled computational power.
This increased computational power results in higher system throughput and more efficient memory utilization when compared to second generation microprocessors. In addition it is very easy to implement into a system because of it's single voltage requirement plus all output signals are fully decoded and timed to control standard memory or peripheral circuits. The circuit is implemented using an N channel, ion implanted, silicon gate MOS process. This device has an internal register configuration which contains 208 bits of Read/Write memory that are accessible to the programmer. The registers include two sets of six general purpose registers that may be used individually as 8bit registers or as 16bit register pairs. There are also two sets of accumulator and flag registers. The programmer has access to either
- Разрядность ядра: 8 бит
- Тактовая частота процессора: 4 МГц
- Тип корпуса: DIP
- Количество выводов: 40
- Диапазон напряжения питания: 4.75 В ... 5.25 В
- Рабочий диапазон температрур: 0°C ... +70°C
- Тактовая частота: 4 МГц
