Datasheet DM84-2012-35-5024 - Durakool Даташит POWER Реле DPDT-2CO 24VAC, 8 А, PC BOARD — Даташит
Наименование модели: DM84-2012-35-5024
![]() Реле Мощности, Relay, Dpst, 250VAC, 24VDC, 8A | |||
DM84-2012-35-5024 Durakool | 455 ₽ | ||
DM84-2012-35-5024 Durakool | 676 ₽ |
Производитель: Durakool
Описание: POWER Реле DPDT-2CO 24VAC, 8 А, PC BOARD
DM84
industrial relays
· Cadmium - free contacts · Height 15,7 mm · 5000 V / 10 mm reinforced insulation · For PCB and plug-in sockets · Accessories: sockets and modules · AC and DC coils · Recyclable packing · Recognitions, certificates, directives: RoHS, 2C/O, 2NO AgNi, AgNi/Au 5 um, AgSnO2 400 V / 300 V 5 V AgNi, 5 V AgNi/Au 5 um, 10 V AgSnO2 8 A / 250 V AC 8 A / 24 V DC 5 mA AgNi, 2 mA AgNi/Au 5 um, 10 mA AgSnO2 15 A AgSnO2 8A 2 000 VA 0,3 W AgNi, 0,05 W AgNi/Au 5 um, 1 W AgSnO2 100 m 600 cycles/hour 72 000 cycles/hour 12...240 V 3...110 V AC: 0,15 Un DC: 0,1 Un see Tables 1, 2 and Fig.
4, 5 0,75 VA 0,4...0,48 W C250 / B400 400 V AC 4 000 V AC III IEC 61810-5 (PN-IEC 664-1) 3 5 000 V AC 1 000 V AC 2 500 V AC 10 mm 10 mm 7 ms 3 ms > 105 8 A, 250 V AC see Fig. 2 > 105 0,15 A, 220 V DC > 3 x 107 29 x 12,7 x 15,7 mm 14 g -40...+85 oC AC: -40...+70 oC DC: -40...+85 oC IP 40 or IP 67 RTII IEC 61810-7 20 g 10 g / 5 g 10...150 Hz max. 270 oC max. 5 s
R
Contacts Contact number & arra
- Тип реле: General Purpose
- Coil Voltage VAC Nom: 24 В
- Contact Current Max: 8 А
- Contact Voltage AC Nom: 250 В
- Contact Voltage DC Nom: 24 В
- Coil Resistance: 400 Ом
- Contacts: DPDT-2C/O
DM842012355024, DM84 2012 35 5024
