Datasheet DM85-2011-35-5120 - Durakool Даташит POWER Реле, SPDT-CO, 120VAC, 16 А, PCB — Даташит
Наименование модели: DM85-2011-35-5120
![]() Реле и Аксессуары , Automotive Relay; Series: DG85; Coil Voltage VAC Nom: 120V; Coil Resistance: 10200Ω; No. of Poles: 1; Contacts:... | |||
DM85-2011-35-5120 Durakool | 410 ₽ | ||
DM85-2011-35-5120 Durakool | 505 ₽ |
Производитель: Durakool
Описание: POWER Реле, SPDT-CO, 120VAC, 16 А, PCB
DM85
industrial relays
· Cadmium - free contacts · Height 15,7 mm · 5000 V / 10 mm reinforced insulation · For PCB and plug-in sockets · Accessories: sockets and modules · AC and DC coils · Recyclable packing · Recognitions, certificates, directives: RoHS, 1C/O, 1NO AgNi, AgSnO2 400 V / 300 V 5 V AgNi, 10 V AgSnO2 16 A / 250 V AC 16 A / 24 V DC 5 mA AgNi, 10 mA AgSnO2 30 A AgSnO2 16 A 4 000 VA 0,3 W AgNi, 1 W AgSnO2 100 m 600 cycles/hour 72 000 cycles/hour 12...240 V 3...110 V AC: 0,15 Un DC: 0,1 Un see Tables 1, 2 and Fig.
4, 5 0,75 VA 0,4...0,48 W C250 / B400 400 V AC 4 000 V AC III IEC 61810-5 (PN-IEC 664-1) 3 5 000 V AC 1 000 V AC 10 mm 10 mm 7 ms 3 ms > 0,7 x 105 16 A, 250 V AC see Fig. 2 > 105 0,15 A, 220 V DC > 3 x 107 29 x 12,7 x 15,7 mm 14 g -40...+85 oC AC: -40...+70 oC DC: -40...+85 oC IP 40 or IP 67 RTII IEC 61810-7 30 g 10 g 10...150 Hz max. 270 oC max. 5 s
R
Contacts Contact number & arrangement Contact material Max. switching voltage Min. switching voltage Rated l
- Тип реле: General Purpose
- Coil Voltage VAC Nom: 120 В
- Contact Current Max: 16 А
- Contact Voltage AC Nom: 400 В
- Contact Voltage DC Nom: 300 В
- Coil Resistance: 10200 Ом
- Contacts: SPDT-C/O
DM852011355120, DM85 2011 35 5120
