Datasheet DM87N-2011-35-1012 - Durakool Даташит POWER Реле SPDT-CO 12 В DC, 10 А, PC BOARD — Даташит
Наименование модели: DM87N-2011-35-1012
Производитель: Durakool
Описание: POWER Реле SPDT-CO 12 В DC, 10 А, PC BOARD
DM87
industrial relays
DM87N sensitive
Contacts Contact number & arrangement Contact material Max.
switching voltage Min. switching voltage Rated load Min. switching current Max. inrush current Rated current Max. breaking capacity Min. breaking capacity Resistance Max. operating frequency · at rated load · no load Coil Rated voltage Must release voltage Operating range of supply voltage Rated power consumption Insulation Insulation category Insulation rated voltage Rated surge voltage Overvoltage category Insulation pollution degree Dielectric strength · coil - contact · contact - contact Contact - coil distance · clearance · creepage General data Operating time (typical value) Release time (typical value) Electrical life · resistive AC1 · cos · L/R=40 ms Mechanical life (cycles) Dimensions (L x W x H) Weight Ambient temperature Cover protection category Environmental protection Shock resistance Vibration resistance Solder bath temperature Soldering time
· Cadmium - free contacts · H
- Тип реле: High Sensitivity
- Coil Voltage VDC Nom: 12 В
- Contact Current Max: 10 А
- Contact Voltage AC Nom: 250 В
- Contact Voltage DC Nom: 24 В
- Coil Resistance: 360 Ом
- Contacts: SPDT-C/O
DM87N2011351012, DM87N 2011 35 1012
