Datasheet DP6-1P-115VAC/DC - Durakool Даташит POWER Реле SPDT 115VAC/DC, 6 А, DIN RAIL — Даташит
Наименование модели: DP6-1P-115VAC/DC
Производитель: Durakool
Описание: POWER Реле SPDT 115VAC/DC, 6 А, DIN RAIL
DP6-1P
industrial relays
· Relays DP6-1P - with changeover relay, rated load 6 A / 250 V (AC1) · 35 mm DIN rail mount, EN 50022, wires connection with screw terminals - 0.2...4 mm2 · Adapted for the co-operation with interconnection strip type DG20 · Equipped in LED green · Recognitions, certificates, directives:
R
VDE
- Тип реле: General Purpose
- Coil Voltage VAC Nom: 115 В
- Coil Voltage VDC Nom: 115 В
- Contact Current Max: 6 А
- Contact Voltage AC Nom: 250 В
- Contact Voltage DC Nom: 24 В
- Contacts: SPDT-C/O
DP61P115VAC/DC, DP6 1P 115VAC/DC
