Datasheet DP6-OC-24VAC/DC - Durakool Даташит POWER Реле, 24VAC/DC, 500 мА, DIN RAIL — Даташит
Наименование модели: DP6-OC-24VAC/DC
Производитель: Durakool
Описание: POWER Реле, 24VAC/DC, 500 мА, DIN RAIL
DP6-OC
industrial relays
· Relays DP6-OC - with transistor output, rated load up to 0.5 A / 70 V DC · 35 mm DIN rail mount, EN 50022, wires connection with screw terminals - 0.2...4 mm2 · Adapted for the co-operation with interconnection strip type ZG20 · Equipped in LED green · Recognitions, certificates, directives:
Transistor - output
Max.
switching voltage Min. switching voltage Rated load Min. switching current DC DC DC1 70 V 5V 0.5 A / 70 V DC 1 mA 5...32 V 24-230 V AC: 50/60 Hz AC: 0.2 Un DC: 0.1 Un 0.3 W 0.3 VA / 0.3 W 24 V AC/DC 1.0 VA / 1.0 W 230 V AC/DC C250 600 V AC 3 000 V AC 2 10 kHz ------80 x 6.2 x 40 g 5...32 V DC (for load up to 24 V DC - 15 KHz) 24 V AC/DC 230 V AC/DC 93.8 mm
- Тип реле: General Purpose
- Coil Voltage VAC Nom: 24 В
- Coil Voltage VDC Nom: 24 В
- Contact Current Max: 500 мА
- Contact Voltage DC Nom: 70 В
- Coil Type: AC / DC
- Nom Operating Power: 300 мВт
DP6OC24VAC/DC, DP6 OC 24VAC/DC
