Datasheet RH1B-UAC12V - IDEC Даташит POWER Реле, SPDT, 12VAC, 10 А, PLUG IN — Даташит
Наименование модели: RH1B-UAC12V
Купить RH1B-UAC12V на РадиоЛоцман.Цены — от 471 до 2 602 ₽5 предложений от 5 поставщиков Реле Мощности, Electromechanical Relay SPDT 10A 12VAC 165Ω Socket | |||
| RH1B-UAC12V IDEC | 770 ₽ | ||
| RH1B-UAC12V IDEC | 2 602 ₽ | ||
| RH1B-U-AC12V | по запросу | ||
| RH1BUAC12V | по запросу | ||
Производитель: IDEC
Описание: POWER Реле, SPDT, 12VAC, 10 А, PLUG IN
RH Series RH Series -- General Purpose Midget Relays
Key features of the RH series include: · Compact midget size saves space · High switching capacity (10A) · Choice of blade or PCB style terminals · Relay options include indicator light, check button, and top mounting bracket · DIN rail, surface, panel, and PCB type sockets available for a wide range of mounting applications Contact Material Contact Resistance Minimum Applicable Load Operating Time
Silver cadmium oxide 50m maximum (initial value) 24V DC/30mA, 5V DC/100mA (reference value) SPDT (RH1), DPDT (RH2): 20ms maximum 3PDT (RH3), 4PDT (RH4): 25ms maximum SPDT (RH1), DPDT (RH2): 20ms maximum 3PDT (RH3), 4PDT (RH4): 25ms maximum 110% of the rated voltage
Relays
E
- Тип реле: Miniature
- Coil Voltage VAC Nom: 12 В
- Contact Current Max: 10 А
- Contact Voltage AC Nom: 220 В
- Contact Voltage DC Nom: 30 В
- Coil Resistance: 78.8 Ом
- Contacts: SPDT
- Coil Type: AC
RH1BUAC12V, RH1B UAC12V
