Datasheet RH1B-UTAC120V - IDEC Даташит POWER Реле, SPDT, 120VAC, 10 А, PLUG IN — Даташит
Наименование модели: RH1B-UTAC120V
Купить RH1B-UTAC120V на РадиоЛоцман.Цены — от 494 до 1 724 ₽17 предложений от 8 поставщиков Реле Мощности, Power Relay 120VAC 10A SPDT (( 43.2mm 14.5mm 42mm)) Bracket Mount | |||
| RH1B-UTAC120V | от 958 ₽ | ||
| RH1B-UTAC120V IDEC | от 1 619 ₽ | ||
| RH1BUTAC120V | по запросу | ||
| RH1B-UTAC120V IDEC | по запросу | ||
Производитель: IDEC
Описание: POWER Реле, SPDT, 120VAC, 10 А, PLUG IN
RH Series RH Series -- General Purpose Midget Relays
Key features of the RH series include: · Compact midget size saves space · High switching capacity (10A) · Choice of blade or PCB style terminals · Relay options include indicator light, check button, and top mounting bracket · DIN rail, surface, panel, and PCB type sockets available for a wide range of mounting applications Contact Material Contact Resistance Minimum Applicable Load Operating Time
Silver cadmium oxide 50m maximum (initial value) 24V DC/30mA, 5V DC/100mA (reference value) SPDT (RH1), DPDT (RH2): 20ms maximum 3PDT (RH3), 4PDT (RH4): 25ms maximum SPDT (RH1), DPDT (RH2): 20ms maximum 3PDT (RH3), 4PDT (RH4): 25ms maximum 110% of the rated voltage
Relays
E
- Тип реле: Miniature
- Coil Voltage VAC Nom: 120 В
- Contact Current Max: 10 А
- Contact Voltage AC Nom: 220 В
- Contact Voltage DC Nom: 30 В
- Coil Resistance: 7680 Ом
- Contacts: SPDT
- Coil Type: AC
RH1BUTAC120V, RH1B UTAC120V
