Datasheet RH1B-UTDC24V - IDEC Даташит POWER Реле, SPDT, 24 В DC, 10 А, PLUG IN — Даташит
IDEC RH1B-UTDC24V
Наименование модели: RH1B-UTDC24V
15 предложений от 7 поставщиков
Реле Мощности, Power Relay 24VDC 10A SPDT (( 43.2mm 14.5mm 42mm)) Bracket Mount
RH1B-UTDC24V
IDEC
798 ₽
Элитан
RH1B-UTDC24V
IDEC
2 533 ₽
RH1B-UTDC24V
IDEC
ТаймЧипс
RH1B-UTDC24V
Производитель: IDEC
Описание: POWER Реле, SPDT, 24 В DC, 10 А, PLUG IN
data sheetСкачать Data Sheet
RH Series RH Series -- General Purpose Midget Relays
Key features of the RH series include: · Compact midget size saves space · High switching capacity (10A) · Choice of blade or PCB style terminals · Relay options include indicator light, check button, and top mounting bracket · DIN rail, surface, panel, and PCB type sockets available for a wide range of mounting applications Contact Material Contact Resistance Minimum Applicable Load Operating Time
Silver cadmium oxide 50m maximum (initial value) 24V DC/30mA, 5V DC/100mA (reference value) SPDT (RH1), DPDT (RH2): 20ms maximum 3PDT (RH3), 4PDT (RH4): 25ms maximum SPDT (RH1), DPDT (RH2): 20ms maximum 3PDT (RH3), 4PDT (RH4): 25ms maximum 110% of the rated voltage
Relays
E
  • Тип реле: Miniature
  • Coil Voltage VDC Nom: 24 В
  • Contact Current Max: 10 А
  • Contact Voltage AC Nom: 220 В
  • Contact Voltage DC Nom: 30 В
  • Coil Resistance: 750 Ом
  • Contacts: SPDT
  • Coil Type: DC
RH1BUTDC24V, RH1B UTDC24V
На английском языке: Datasheet RH1B-UTDC24V - IDEC POWER RELAY, SPDT, 24 V DC, 10 A, PLUG IN
