Datasheet RH1V2-UDC12V - IDEC Даташит POWER Реле, SPDT, 12 В DC, 10 А, PC BOARD — Даташит
IDEC RH1V2-UDC12V
Наименование модели: RH1V2-UDC12V
18 предложений от 8 поставщиков
Реле Мощности, Power Relay 12VDC 10A SPDT (( 27.5mm 14mm 35.6mm)) Through Hole
Зенер
Россия и страны ТС
RH1V2-UDC12V
IDEC
от 1 597 ₽
RH1V2-UDC12V
IDEC
от 1 746 ₽
RH1V2-UDC12V
IDEC
2 158 ₽
ТаймЧипс
RH1V2-UDC12V
Производитель: IDEC
Описание: POWER Реле, SPDT, 12 В DC, 10 А, PC BOARD
data sheetСкачать Data Sheet
RH Series RH Series -- General Purpose Midget Relays
Key features of the RH series include: · Compact midget size saves space · High switching capacity (10A) · Choice of blade or PCB style terminals · Relay options include indicator light, check button, and top mounting bracket · DIN rail, surface, panel, and PCB type sockets available for a wide range of mounting applications Contact Material Contact Resistance Minimum Applicable Load Operating Time
Silver cadmium oxide 50m maximum (initial value) 24V DC/30mA, 5V DC/100mA (reference value) SPDT (RH1), DPDT (RH2): 20ms maximum 3PDT (RH3), 4PDT (RH4): 25ms maximum SPDT (RH1), DPDT (RH2): 20ms maximum 3PDT (RH3), 4PDT (RH4): 25ms maximum 110% of the rated voltage
Relays
E
  • Тип реле: Miniature
  • Coil Voltage VDC Nom: 12 В
  • Contact Current Max: 10 А
  • Contact Voltage AC Nom: 220 В
  • Contact Voltage DC Nom: 30 В
  • Coil Resistance: 188 Ом
  • Contacts: SPDT
  • Coil Type: DC
RH1V2UDC12V, RH1V2 UDC12V
На английском языке: Datasheet RH1V2-UDC12V - IDEC POWER RELAY, SPDT, 12 V DC, 10 A, PC BOARD
