Datasheet RH2B-UTDC12V - IDEC Даташит POWER Реле, DPDT, 12 В DC, 10 А, PLUG IN — Даташит
Наименование модели: RH2B-UTDC12V
![]() 14 предложений от 7 поставщиков AVX Advanced Ceramic Capacitors for Power Supply, High Voltage and Tip and Ring Applications | |||
RH2B-UTDC12V IDEC | 747 ₽ | ||
RH2B-UTDC12V IDEC | 2 407 ₽ | ||
RH2BUTDC12V AVX | по запросу | ||
RH2B-UTDC12V | по запросу |
Производитель: IDEC
Описание: POWER Реле, DPDT, 12 В DC, 10 А, PLUG IN
RH Series RH Series -- General Purpose Midget Relays
Key features of the RH series include: · Compact midget size saves space · High switching capacity (10A) · Choice of blade or PCB style terminals · Relay options include indicator light, check button, and top mounting bracket · DIN rail, surface, panel, and PCB type sockets available for a wide range of mounting applications Contact Material Contact Resistance Minimum Applicable Load Operating Time
Silver cadmium oxide 50m maximum (initial value) 24V DC/30mA, 5V DC/100mA (reference value) SPDT (RH1), DPDT (RH2): 20ms maximum 3PDT (RH3), 4PDT (RH4): 25ms maximum SPDT (RH1), DPDT (RH2): 20ms maximum 3PDT (RH3), 4PDT (RH4): 25ms maximum 110% of the rated voltage
Relays
E
- Тип реле: Miniature
- Coil Voltage VDC Nom: 12 В
- Contact Current Max: 10 А
- Contact Voltage AC Nom: 220 В
- Contact Voltage DC Nom: 30 В
- Coil Resistance: 160 Ом
- Contacts: DPDT
- Coil Type: DC
RH2BUTDC12V, RH2B UTDC12V
