Datasheet RH2V2-UAC110-120V - IDEC Даташит POWER Реле, DPDT, 120VAC, 10 А, PC BOARD — Даташит
IDEC RH2V2-UAC110-120V
Наименование модели: RH2V2-UAC110-120V
15 предложений от 8 поставщиков
Реле Мощности, Power Relay 110V/120VAC 10A DPDT (( 27.5mm 41mm 42mm)) Through Hole
RH2V2-UAC110-120V
IDEC
485 ₽
Элитан
RH2V2-UAC110-120V
IDEC
1 658 ₽
RH2V2-UAC110-120V
ТаймЧипс
RH2V2-U-AC110-120V
AVX
Производитель: IDEC
Описание: POWER Реле, DPDT, 120VAC, 10 А, PC BOARD
data sheetСкачать Data Sheet
RH Series RH Series -- General Purpose Midget Relays
Key features of the RH series include: · Compact midget size saves space · High switching capacity (10A) · Choice of blade or PCB style terminals · Relay options include indicator light, check button, and top mounting bracket · DIN rail, surface, panel, and PCB type sockets available for a wide range of mounting applications Contact Material Contact Resistance Minimum Applicable Load Operating Time
Silver cadmium oxide 50m maximum (initial value) 24V DC/30mA, 5V DC/100mA (reference value) SPDT (RH1), DPDT (RH2): 20ms maximum 3PDT (RH3), 4PDT (RH4): 25ms maximum SPDT (RH1), DPDT (RH2): 20ms maximum 3PDT (RH3), 4PDT (RH4): 25ms maximum 110% of the rated voltage
Relays
E
  • Тип реле: Miniature
  • Coil Voltage VAC Nom: 120 В
  • Contact Current Max: 10 А
  • Contact Voltage AC Nom: 220 В
  • Contact Voltage DC Nom: 30 В
  • Coil Resistance: 4170 Ом
  • Contacts: DPDT
  • Coil Type: AC
RH2V2UAC110120V, RH2V2 UAC110 120V
На английском языке: Datasheet RH2V2-UAC110-120V - IDEC POWER RELAY, DPDT, 120VAC, 10 A, PC BOARD
