Datasheet RH3B-ULAC120V - IDEC Даташит POWER Реле, 3PDT, 120VAC, 10 А, PLUG IN — Даташит
IDEC RH3B-ULAC120V
Наименование модели: RH3B-ULAC120V
15 предложений от 8 поставщиков
AVX Advanced Ceramic Capacitors for Power Supply, High Voltage and Tip and Ring Applications
Эиком
RH3B-ULAC120V
IDEC
от 3 007 ₽
RH3B-ULAC120V
IDEC
3 750 ₽
RH3B-ULAC120V
IDEC
9 535 ₽
TradeElectronics
RH3B-ULAC120V
AVX
Производитель: IDEC
Описание: POWER Реле, 3PDT, 120VAC, 10 А, PLUG IN
data sheetСкачать Data Sheet
RH Series RH Series -- General Purpose Midget Relays
Key features of the RH series include: · Compact midget size saves space · High switching capacity (10A) · Choice of blade or PCB style terminals · Relay options include indicator light, check button, and top mounting bracket · DIN rail, surface, panel, and PCB type sockets available for a wide range of mounting applications Contact Material Contact Resistance Minimum Applicable Load Operating Time
Silver cadmium oxide 50m maximum (initial value) 24V DC/30mA, 5V DC/100mA (reference value) SPDT (RH1), DPDT (RH2): 20ms maximum 3PDT (RH3), 4PDT (RH4): 25ms maximum SPDT (RH1), DPDT (RH2): 20ms maximum 3PDT (RH3), 4PDT (RH4): 25ms maximum 110% of the rated voltage
Relays
E
  • Тип реле: Miniature
  • Coil Voltage VAC Nom: 120 В
  • Contact Current Max: 10 А
  • Contact Voltage AC Nom: 220 В
  • Contact Voltage DC Nom: 30 В
  • Coil Resistance: 2770 Ом
  • Contacts: 3PDT
  • Coil Type: AC
RH3BULAC120V, RH3B ULAC120V
На английском языке: Datasheet RH3B-ULAC120V - IDEC POWER RELAY, 3PDT, 120VAC, 10 A, PLUG IN
