Datasheet RH4B-ULDC24V - IDEC Даташит POWER Реле, 4PDT, 24 В DC, 10 А, PLUG IN — Даташит
Наименование модели: RH4B-ULDC24V
![]() 21 предложений от 10 поставщиков Реле питания, 4PDT, 24 В DC, 10 А, RH Series, Гнездо, Без Защелки | |||
RH4B-ULDC24V IDEC | от 3 375 ₽ | ||
RH4B-ULDC24V IDEC | от 6 736 ₽ | ||
RH4B-UL-DC24V AVX | по запросу | ||
RH4B-ULDC24V AVX | по запросу |
Производитель: IDEC
Описание: POWER Реле, 4PDT, 24 В DC, 10 А, PLUG IN
RH Series RH Series -- General Purpose Midget Relays
Key features of the RH series include: · Compact midget size saves space · High switching capacity (10A) · Choice of blade or PCB style terminals · Relay options include indicator light, check button, and top mounting bracket · DIN rail, surface, panel, and PCB type sockets available for a wide range of mounting applications Contact Material Contact Resistance Minimum Applicable Load Operating Time
Silver cadmium oxide 50m maximum (initial value) 24V DC/30mA, 5V DC/100mA (reference value) SPDT (RH1), DPDT (RH2): 20ms maximum 3PDT (RH3), 4PDT (RH4): 25ms maximum SPDT (RH1), DPDT (RH2): 20ms maximum 3PDT (RH3), 4PDT (RH4): 25ms maximum 110% of the rated voltage
Relays
E
- Тип реле: Miniature
- Coil Voltage VDC Nom: 24 В
- Contact Current Max: 10 А
- Contact Voltage AC Nom: 220 В
- Contact Voltage DC Nom: 30 В
- Coil Resistance: 388 Ом
- Contacts: 4PDT
- Coil Type: DC
RH4BULDC24V, RH4B ULDC24V
