Datasheet RJ1S-C-A240 - IDEC Даташит POWER Реле, SPDT, 240VAC, 12 А, PLUG IN — Даташит
IDEC RJ1S-C-A240
Наименование модели: RJ1S-C-A240
12 предложений от 6 поставщиков
Реле Мощности, Electromechanical Relay 240VAC 25.57KΩ 12A SPDT(28.8x12.7x32)mm Socket General Purpose Relay
RJ1S-C-A240
IDEC
655 ₽
Зенер
Россия и страны ТС
RJ1S-C-A240
от 1 009 ₽
RJ1S-C-A240
IDEC
от 2 340 ₽
Элитан
RJ1S-C-A240
IDEC
2 573 ₽
Производитель: IDEC
Описание: POWER Реле, SPDT, 240VAC, 12 А, PLUG IN
data sheetСкачать Data Sheet
Relays
RJ Series -- General Purpose Relays
RJ relays, the newest addition to our relay family, were designed with the same attention-to-detail IDEC is known for.
One feature that exemplifies this is an optional LED. It uses a unique light guide to give you a brighter and more noticeable status indicator from multiple directions. Key features of the RJ series include: · Compact size: 12.7 x 27 x 28.8 mm · Contact rating: 8A (DPDT), 12A (SPDT) · Operational life: 200K cycles at full resistive load 50 million cycles, no load · Optional, green, non-polarized LED · RoHS compliant RJ1S
No. of poles Contact Configuration Contact Rating Contact Material Contact Resistance Operating Time Release Time Dielectric Strength Between contact and coil Between contacts Damage limits Operating extremes Damage limits Operating extremes AC DC AC DC 1 SPDT 12A 2 DPDT 8A
RJ Series
  • Тип реле: General Purpose
  • Coil Voltage VAC Nom: 240 В
  • Contact Current Max: 12 А
  • Contact Voltage AC Nom: 250 В
  • Contact Voltage DC Nom: 30 В
  • Coil Resistance: 25570 Ом
  • Contacts: SPDT
  • Coil Type: AC
RJ1SCA240, RJ1S C A240
На английском языке: Datasheet RJ1S-C-A240 - IDEC POWER RELAY, SPDT, 240VAC, 12 A, PLUG IN
