Datasheet RJ1S-CL-D12 - IDEC Даташит POWER Реле, SPDT, 12 В DC, 12 А, PLUG IN — Даташит
Наименование модели: RJ1S-CL-D12
Купить RJ1S-CL-D12 на РадиоЛоцман.Цены — от 150 до 1 533 ₽23 предложений от 10 поставщиков Реле Мощности, Relay; E-Mech; SPDT; Ctrl-V 12DC; 12A; 250VAC; Socket Mount; Blade; LED; RJ Series | |||
| RJ1S-CL-D12 IDEC | от 594 ₽ | ||
| RJ1S-CL-D12 IDEC | от 1 418 ₽ | ||
| RJ1S-CL-D12 IDEC | от 1 456 ₽ | ||
| RJ1S-CL-D12 IDEC | по запросу | ||
Производитель: IDEC
Описание: POWER Реле, SPDT, 12 В DC, 12 А, PLUG IN
Relays
RJ Series -- General Purpose Relays
RJ relays, the newest addition to our relay family, were designed with the same attention-to-detail IDEC is known for.
One feature that exemplifies this is an optional LED. It uses a unique light guide to give you a brighter and more noticeable status indicator from multiple directions. Key features of the RJ series include: · Compact size: 12.7 x 27 x 28.8 mm · Contact rating: 8A (DPDT), 12A (SPDT) · Operational life: 200K cycles at full resistive load 50 million cycles, no load · Optional, green, non-polarized LED · RoHS compliant RJ1S
No. of poles Contact Configuration Contact Rating Contact Material Contact Resistance Operating Time Release Time Dielectric Strength Between contact and coil Between contacts Damage limits Operating extremes Damage limits Operating extremes AC DC AC DC 1 SPDT 12A 2 DPDT 8A
RJ Series
- Тип реле: General Purpose
- Coil Voltage VDC Nom: 12 В
- Contact Current Max: 12 А
- Contact Voltage AC Nom: 250 В
- Contact Voltage DC Nom: 30 В
- Coil Resistance: 540 Ом
- Contacts: SPDT
- Coil Type: DC
RJ1SCLD12, RJ1S CL D12
