Клеммники KEEN SIDE
Datasheet RJ2S-CL-A24 - IDEC Даташит POWER Реле, DPDT, 24VAC, 8 А, PLUG IN — Даташит
IDEC RJ2S-CL-A24
Наименование модели: RJ2S-CL-A24
20 предложений от 11 поставщиков
Реле Мощности, Relay; E-Mech; DPDT; Ctrl-V 24AC; 8A; 250VAC; Socket Mount; Blade; LED; RJ Series
RJ2S-CL-A24
IDEC
370 ₽
Элитан
RJ2S-CL-A24
IDEC
1 440 ₽
RJ2S-CL-A24
IDEC
RJ2S-CL-A24
Производитель: IDEC
Описание: POWER Реле, DPDT, 24VAC, 8 А, PLUG IN
data sheetСкачать Data Sheet
Relays
RJ Series -- General Purpose Relays
RJ relays, the newest addition to our relay family, were designed with the same attention-to-detail IDEC is known for.
One feature that exemplifies this is an optional LED. It uses a unique light guide to give you a brighter and more noticeable status indicator from multiple directions. Key features of the RJ series include: · Compact size: 12.7 x 27 x 28.8 mm · Contact rating: 8A (DPDT), 12A (SPDT) · Operational life: 200K cycles at full resistive load 50 million cycles, no load · Optional, green, non-polarized LED · RoHS compliant RJ1S
No. of poles Contact Configuration Contact Rating Contact Material Contact Resistance Operating Time Release Time Dielectric Strength Between contact and coil Between contacts Damage limits Operating extremes Damage limits Operating extremes AC DC AC DC 1 SPDT 12A 2 DPDT 8A
RJ Series
  • Тип реле: General Purpose
  • Coil Voltage VAC Nom: 24 В
  • Contact Current Max: 8 А
  • Contact Voltage AC Nom: 250 В
  • Contact Voltage DC Nom: 30 В
  • Coil Resistance: 232 Ом
  • Contacts: DPDT
  • Coil Type: AC
RJ2SCLA24, RJ2S CL A24
На английском языке: Datasheet RJ2S-CL-A24 - IDEC POWER RELAY, DPDT, 24VAC, 8 A, PLUG IN
