Datasheet RJ2V-A-D12 - IDEC Даташит POWER Реле, DPST-NO, 12 В DC, 8 А PC BOARD — Даташит
IDEC RJ2V-A-D12
Наименование модели: RJ2V-A-D12
Реле Мощности, IDEC RJ2V-A-D12 Power Relay, DPST-NO, 12VDC, 8A, RJ Series, Through Hole, Non Latching
RJ2V-A-D12
IDEC
212 ₽
Производитель: IDEC
Описание: POWER Реле, DPST-NO, 12 В DC, 8 А PC BOARD
data sheetСкачать Data Sheet
RJ Series Relays
Features
· Compact size: Blade: 12.7 x 27 x 28.8 mm PCB: 12.7 x 25.5 x 28.8 mm · Contact rating: Blade: 8A (DPDT), 12A (SPDT) PCB: 8A (DPDT & DPST-NO), 12A (SPDT & SPST-NO), 16A (SPDT & SPST-NO) · Operational life: 200K cycles at full resistive AC load; 50 million cycles, no load · Blade model has optional green, non-polarized LED · RoHS compliant
PCB Models ! Now Available
NEW
  • Тип реле: Miniature
  • Coil Voltage VDC Nom: 12 В
  • Contact Current Max: 8 А
  • Contact Voltage AC Nom: 250 В
  • Contact Voltage DC Nom: 30 В
  • Coil Resistance: 271 Ом
  • Contacts: DPST
  • Coil Type: DC
RJ2VAD12, RJ2V A D12
На английском языке: Datasheet RJ2V-A-D12 - IDEC POWER RELAY, DPST-NO, 12 V DC, 8 A PC BOARD
