Datasheet RJ2V-C-D12 - IDEC Даташит POWER Реле, DPDT, 12 В DC, 8 А, PC BOARD — Даташит
Наименование модели: RJ2V-C-D12
Купить RJ2V-C-D12 на РадиоЛоцман.Цены — от 171 до 2 000 ₽Реле Мощности, IDEC RJ2V-C-D12 Power Relay, DPDT, 12VDC, 8A, RJ Series, Through Hole, Non Latching | |||
| RJ2V-C-D12 IDEC | 171 ₽ | ||
| RJ2V-C-D12 IDEC | 295 ₽ | ||
| RJ2V-C-D12 IDEC | 2 000 ₽ | ||
| RJ2V-C-D12 | по запросу | ||
Производитель: IDEC
Описание: POWER Реле, DPDT, 12 В DC, 8 А, PC BOARD
RJ Series Relays
Features
· Compact size: Blade: 12.7 x 27 x 28.8 mm PCB: 12.7 x 25.5 x 28.8 mm · Contact rating: Blade: 8A (DPDT), 12A (SPDT) PCB: 8A (DPDT & DPST-NO), 12A (SPDT & SPST-NO), 16A (SPDT & SPST-NO) · Operational life: 200K cycles at full resistive AC load; 50 million cycles, no load · Blade model has optional green, non-polarized LED · RoHS compliant
PCB Models ! Now Available
NEW
- Тип реле: Miniature
- Coil Voltage VDC Nom: 12 В
- Contact Current Max: 8 А
- Contact Voltage AC Nom: 250 В
- Contact Voltage DC Nom: 30 В
- Coil Resistance: 271 Ом
- Contacts: DPDT
- Coil Type: DC
RJ2VCD12, RJ2V C D12
