Datasheet RQ1V-CM-A115 - IDEC Даташит POWER Реле, SPDT, 120VAC, 12 А, PC BOARD — Даташит
IDEC RQ1V-CM-A115
Наименование модели: RQ1V-CM-A115
14 предложений от 7 поставщиков
Реле Мощности, Electromechanical Relay SPDT 12A 115VAC 8.1KΩ Through Hole
Зенер
Россия и страны ТС
RQ1V-CM-A115
от 422 ₽
RQ1V-CM-A115
IDEC
559 ₽
RQ1V-CM-A115
IDEC
от 1 032 ₽
Элитан
RQ1V-CM-A115
IDEC
1 757 ₽
Производитель: IDEC
Описание: POWER Реле, SPDT, 120VAC, 12 А, PC BOARD
data sheetСкачать Data Sheet
RQ Series RQ Series -- General Purpose Relays
IDEC's RQ relays are low-profile, PCB relays that provide quality within a compact package.
Size equals value. RQ relays are small, yet maintain high contact ratings and long operational life. For larger power needs, a 16A model is also available. Key features of the RQ series include: · Low profile: 29 x 12.7 x 15 mm · Contact rating: 8A (DPDT) and 12A (SPDT) · Power relay model with 16A contact rating (SPDT) · Operational life: 100K cycles at full resistive load 10 million cycles, no load · LED/Diode Plug-in modules available with DIN rail socket · Lead-free
Relays
E
Relays
  • Тип реле: General Purpose
  • Coil Voltage VAC Nom: 120 В
  • Contact Current Max: 12 А
  • Coil Resistance: 8100 Ом
  • Contacts: SPDT
  • Coil Type: AC, Sensitive
  • Coil Current: 6.3 мА
  • Nom Operating Power: 730 мВт
RQ1VCMA115, RQ1V CM A115
На английском языке: Datasheet RQ1V-CM-A115 - IDEC POWER RELAY, SPDT, 120VAC, 12 A, PC BOARD
