Datasheet RQ1V-CM-D24 - IDEC Даташит POWER Реле, SPDT, 24 В DC, 12 А, PC BOARD — Даташит
Наименование модели: RQ1V-CM-D24
Купить RQ1V-CM-D24 на РадиоЛоцман.Цены — от 239 до 843 ₽15 предложений от 7 поставщиков Реле Мощности, Electromechanical Relay SPDT 12A 24VDC 1.44KΩ Through Hole | |||
| RQ1V-CM-D24 IDEC | 266 ₽ | ||
| RQ1V-CM-D24 IDEC | от 843 ₽ | ||
| RQ1VCMD24 | по запросу | ||
| RQ1V-CM-D24 | по запросу | ||
Производитель: IDEC
Описание: POWER Реле, SPDT, 24 В DC, 12 А, PC BOARD
RQ Series RQ Series -- General Purpose Relays
IDEC's RQ relays are low-profile, PCB relays that provide quality within a compact package.
Size equals value. RQ relays are small, yet maintain high contact ratings and long operational life. For larger power needs, a 16A model is also available. Key features of the RQ series include: · Low profile: 29 x 12.7 x 15 mm · Contact rating: 8A (DPDT) and 12A (SPDT) · Power relay model with 16A contact rating (SPDT) · Operational life: 100K cycles at full resistive load 10 million cycles, no load · LED/Diode Plug-in modules available with DIN rail socket · Lead-free
Relays
E
Relays
- Тип реле: General Purpose
- Coil Voltage VDC Nom: 24 В
- Contact Current Max: 12 А
- Coil Resistance: 1440 Ом
- Contacts: SPDT
- Coil Type: DC, Sensitive
- Coil Current: 16.7 мА
- Nom Operating Power: 400 мВт
RQ1VCMD24, RQ1V CM D24
