Datasheet RQ2V-CN-A115 - IDEC Даташит POWER Реле, DPDT, 120VAC, 8 А, PC BOARD — Даташит
Наименование модели: RQ2V-CN-A115
![]() 7 предложений от 7 поставщиков Реле Мощности, Electromechanical Relay DPDT 8A 115VAC 8.1KΩ Through Hole | |||
RQ2V-CN-A115 IDEC | 346 ₽ | ||
RQ2VCNA115 | по запросу | ||
RQ2V-CN-A115 | по запросу | ||
RQ2V-CN-A115 IDEC | по запросу |
Производитель: IDEC
Описание: POWER Реле, DPDT, 120VAC, 8 А, PC BOARD
RQ Series RQ Series -- General Purpose Relays
IDEC's RQ relays are low-profile, PCB relays that provide quality within a compact package.
Size equals value. RQ relays are small, yet maintain high contact ratings and long operational life. For larger power needs, a 16A model is also available. Key features of the RQ series include: · Low profile: 29 x 12.7 x 15 mm · Contact rating: 8A (DPDT) and 12A (SPDT) · Power relay model with 16A contact rating (SPDT) · Operational life: 100K cycles at full resistive load 10 million cycles, no load · LED/Diode Plug-in modules available with DIN rail socket · Lead-free
Relays
E
Relays
- Тип реле: General Purpose
- Coil Voltage VAC Nom: 120 В
- Contact Current Max: 8 А
- Coil Resistance: 8100 Ом
- Contacts: DPDT
- Coil Type: AC, Sensitive
- Coil Current: 6.3 мА
- Nom Operating Power: 730 мВт
RQ2VCNA115, RQ2V CN A115
