Datasheet RR2BA-UAC120V - IDEC Даташит POWER Реле, DPDT, 120VAC, 10 А, PLUG IN — Даташит
Наименование модели: RR2BA-UAC120V
![]() 16 предложений от 9 поставщиков Реле Мощности, IDEC RR2BA-UAC120V RELAY, DPDT, 120VAC, 30VDC, 10A | |||
RR2BA-UAC120V IDEC | 1 175 ₽ | ||
RR2BA-UAC120V IDEC | от 2 807 ₽ | ||
RR2BA-UAC120V IDEC | 2 847 ₽ | ||
RR2BA-UAC120V | по запросу |
Производитель: IDEC
Описание: POWER Реле, DPDT, 120VAC, 10 А, PLUG IN
RR Series RR Series -- General Purpose Power Relays
Key features of the RR series include: · High reliability and long service life · Available in octal (8- and 11-pin) or square (11-blade) base · Options include check button for test operation, indicator light, and side flange (contact IDEC for diodes) · DIN rail, surface and panel type sockets available for a wide range of mounting applications
Relays
Contact Material Contact Resistance Minimum Applicable Load Operating Time
Silver 30m maximum (initial value) 24V DC/10mA, 5V DC/20mA (reference value) 25ms maximum 25ms maximum 110% of the rated voltage UL Recognized File No.
E66043 CSA Certified File No. LR35144
- Тип реле: General Purpose
- Coil Voltage VAC Nom: 120 В
- Contact Current Max: 10 А
- Contact Voltage AC Nom: 220 В
- Contact Voltage DC Nom: 30 В
- Coil Resistance: 2100 Ом
- Contacts: DPDT
- Coil Type: AC
RR2BAUAC120V, RR2BA UAC120V
