Datasheet RR2KP-UDC110V - IDEC Даташит POWER Реле, DPDT, 110 В DC, 10 А, PLUG IN — Даташит
Наименование модели: RR2KP-UDC110V
![]() 13 предложений от 6 поставщиков Реле Мощности, Electromechanical Relay DPDT 10A 110VDC 7.96KΩ Socket | |||
RR2KP-UDC110V IDEC | 3 601 ₽ | ||
RR2KP-UDC110V IDEC | от 10 558 ₽ | ||
RR2KP-UDC110V IDEC | 10 956 ₽ | ||
RR2KP-UDC110V IDEC | от 11 220 ₽ |
Производитель: IDEC
Описание: POWER Реле, DPDT, 110 В DC, 10 А, PLUG IN
Relays
RR2KP Series -- Magnetic Latching Relays
Key features of the RR2KP series include: · Standard octal base (11-pin) termination · Operates by pulse input and maintains condition even during power failure · Coils rated for continuous duty · High vibration and shock resistance · Excellent self-holding performance (magnetic latch) · Optional manual check button for circuit testing · DIN rail, surface, and panel mount sockets available for a wide range of mounting applications
RR2KP Series
Contact Material Contact Resistance Minimum Applicable Load Operating Time Maximum Continuous Applied Voltage (AC/DC) at 20°C Minimum Set and Reset Voltage at 20°C Power Consumption
- Тип реле: Latching
- Coil Voltage VDC Nom: 110 В
- Contact Current Max: 10 А
- Contact Voltage AC Nom: 220 В
- Contact Voltage DC Nom: 100 В
- Coil Resistance: 8460 Ом
- Contacts: DPDT
- Coil Type: DC
RR2KPUDC110V, RR2KP UDC110V
