Datasheet RR2KP-UDC24V - IDEC Даташит POWER Реле, DPDT, 24 В DC, 10 А, PLUG IN — Даташит
IDEC RR2KP-UDC24V
Наименование модели: RR2KP-UDC24V
17 предложений от 8 поставщиков
Реле электромагнитные Силовые реле, более 2 А
RR2KP-UDC24V
IDEC
3 413 ₽
Зенер
Россия и страны ТС
RR2KP-UDC24V
IDEC
от 4 477 ₽
RR2KP-UDC24V
IDEC
от 9 706 ₽
RR2KPUDC24V
Производитель: IDEC
Описание: POWER Реле, DPDT, 24 В DC, 10 А, PLUG IN
data sheetСкачать Data Sheet
Relays
RR2KP Series -- Magnetic Latching Relays
Key features of the RR2KP series include: · Standard octal base (11-pin) termination · Operates by pulse input and maintains condition even during power failure · Coils rated for continuous duty · High vibration and shock resistance · Excellent self-holding performance (magnetic latch) · Optional manual check button for circuit testing · DIN rail, surface, and panel mount sockets available for a wide range of mounting applications
RR2KP Series
Contact Material Contact Resistance Minimum Applicable Load Operating Time Maximum Continuous Applied Voltage (AC/DC) at 20°C Minimum Set and Reset Voltage at 20°C Power Consumption
  • Тип реле: Latching
  • Coil Voltage VDC Nom: 24 В
  • Contact Current Max: 10 А
  • Contact Voltage AC Nom: 220 В
  • Contact Voltage DC Nom: 100 В
  • Coil Resistance: 400 Ом
  • Contacts: DPDT
  • Coil Type: DC
RR2KPUDC24V, RR2KP UDC24V
На английском языке: Datasheet RR2KP-UDC24V - IDEC POWER RELAY, DPDT, 24 V DC, 10 A, PLUG IN
