Datasheet RR2P-UAC24V - IDEC Даташит POWER Реле, DPDT, 24VAC, 10 А, PLUG IN — Даташит
Наименование модели: RR2P-UAC24V
Купить RR2P-UAC24V на РадиоЛоцман.Цены — от 353 до 4 007 ₽25 предложений от 12 поставщиков Реле Мощности, Relay; 10A; 24VAC; DPDT; 29mm W x 55.5mm H x 36mm D; Pin; Silver; Socket | |||
| RR2P-UAC24V IDEC | 898 ₽ | ||
| RR2P-UAC24V IDEC | от 1 381 ₽ | ||
| RR2P-UAC24V IDEC | 4 007 ₽ | ||
| RR2P-UAC24V | по запросу | ||
Производитель: IDEC
Описание: POWER Реле, DPDT, 24VAC, 10 А, PLUG IN
RR Series RR Series -- General Purpose Power Relays
Key features of the RR series include: · High reliability and long service life · Available in octal (8- and 11-pin) or square (11-blade) base · Options include check button for test operation, indicator light, and side flange (contact IDEC for diodes) · DIN rail, surface and panel type sockets available for a wide range of mounting applications
Relays
Contact Material Contact Resistance Minimum Applicable Load Operating Time
Silver 30m maximum (initial value) 24V DC/10mA, 5V DC/20mA (reference value) 25ms maximum 25ms maximum 110% of the rated voltage UL Recognized File No.
E66043 CSA Certified File No. LR35144
- Тип реле: General Purpose
- Coil Voltage VAC Nom: 24 В
- Contact Current Max: 10 А
- Contact Voltage AC Nom: 220 В
- Contact Voltage DC Nom: 30 В
- Coil Resistance: 79 Ом
- Contacts: DPDT
- Coil Type: AC
RR2PUAC24V, RR2P UAC24V
