Datasheet RR3B-UDC24V - IDEC Даташит POWER Реле, 3PDT, 24 В DC, 10 А, PLUG IN — Даташит
IDEC RR3B-UDC24V
Наименование модели: RR3B-UDC24V
23 предложений от 10 поставщиков
Реле Мощности, Power/Signal Relay, 3PDT, Momentary, 0.06A (Coil), 24VDC (Coil), 1500mW (Coil), 10A (Contact), 30VDC (Contact), DC Input, AC-DC Output, Panel...
RR3B-UDC24V
IDEC
1 286 ₽
RR3B-UDC24V
IDEC
от 2 851 ₽
Эиком
RR3B-UDC24V
IDEC
от 2 971 ₽
Элитан
RR3B-UDC24V
IDEC
2 995 ₽
Производитель: IDEC
Описание: POWER Реле, 3PDT, 24 В DC, 10 А, PLUG IN
data sheetСкачать Data Sheet
RR Series RR Series -- General Purpose Power Relays
Key features of the RR series include: · High reliability and long service life · Available in octal (8- and 11-pin) or square (11-blade) base · Options include check button for test operation, indicator light, and side flange (contact IDEC for diodes) · DIN rail, surface and panel type sockets available for a wide range of mounting applications
Relays
Contact Material Contact Resistance Minimum Applicable Load Operating Time
Silver 30m maximum (initial value) 24V DC/10mA, 5V DC/20mA (reference value) 25ms maximum 25ms maximum 110% of the rated voltage UL Recognized File No.
E66043 CSA Certified File No. LR35144
  • Тип реле: General Purpose
  • Coil Voltage VDC Nom: 24 В
  • Contact Current Max: 10 А
  • Contact Voltage AC Nom: 220 В
  • Contact Voltage DC Nom: 30 В
  • Coil Resistance: 400 Ом
  • Contacts: 3PDT
  • Coil Type: DC
RR3BUDC24V, RR3B UDC24V
На английском языке: Datasheet RR3B-UDC24V - IDEC POWER RELAY, 3PDT, 24 V DC, 10 A, PLUG IN
