Datasheet RR3B-ULAC24V - IDEC Даташит POWER Реле, 3PDT, 24 VAC, 10 А, PLUG IN — Даташит
IDEC RR3B-ULAC24V
Наименование модели: RR3B-ULAC24V
22 предложений от 9 поставщиков
Реле Мощности, Power Relay, 3PDT, 24VAC, 10A, RR Series, Socket, Non Latching
RR3B-ULAC24V
IDEC
1 630 ₽
RR3B-ULAC24V
IDEC
1 856 ₽
Элитан
RR3B-ULAC24V
IDEC
4 123 ₽
RR3B-ULAC24V
Производитель: IDEC
Описание: POWER Реле, 3PDT, 24 VAC, 10 А, PLUG IN
data sheetСкачать Data Sheet
RR Series RR Series -- General Purpose Power Relays
Key features of the RR series include: · High reliability and long service life · Available in octal (8- and 11-pin) or square (11-blade) base · Options include check button for test operation, indicator light, and side flange (contact IDEC for diodes) · DIN rail, surface and panel type sockets available for a wide range of mounting applications
Relays
Contact Material Contact Resistance Minimum Applicable Load Operating Time
Silver 30m maximum (initial value) 24V DC/10mA, 5V DC/20mA (reference value) 25ms maximum 25ms maximum 110% of the rated voltage UL Recognized File No.
E66043 CSA Certified File No. LR35144
  • Тип реле: General Purpose
  • Coil Voltage VAC Nom: 24 В
  • Contact Current Max: 10 А
  • Contact Voltage AC Nom: 220 В
  • Contact Voltage DC Nom: 30 В
  • Coil Resistance: 79 Ом
  • Contacts: 3PDT
  • Coil Type: AC
RR3BULAC24V, RR3B ULAC24V
На английском языке: Datasheet RR3B-ULAC24V - IDEC POWER RELAY, 3PDT, 24 VAC, 10 A, PLUG IN
