Datasheet RR3B-ULDC12V - IDEC Даташит POWER Реле, 3PDT, 12 В DC, 10 А, PLUG IN — Даташит
Наименование модели: RR3B-ULDC12V
![]() Реле Мощности, Power Relay 12VDC 10A 3PDT (( 36mm 36mm 47.5mm)) Socket | |||
RR3B-ULDC12V IDEC | 895 ₽ | ||
RR3B-ULDC12V IDEC | 5 111 ₽ | ||
RR3B-ULDC12V | по запросу |
Производитель: IDEC
Описание: POWER Реле, 3PDT, 12 В DC, 10 А, PLUG IN
RR Series RR Series -- General Purpose Power Relays
Key features of the RR series include: · High reliability and long service life · Available in octal (8- and 11-pin) or square (11-blade) base · Options include check button for test operation, indicator light, and side flange (contact IDEC for diodes) · DIN rail, surface and panel type sockets available for a wide range of mounting applications
Relays
Contact Material Contact Resistance Minimum Applicable Load Operating Time
Silver 30m maximum (initial value) 24V DC/10mA, 5V DC/20mA (reference value) 25ms maximum 25ms maximum 110% of the rated voltage UL Recognized File No.
E66043 CSA Certified File No. LR35144
- Тип реле: General Purpose
- Coil Voltage VDC Nom: 12 В
- Contact Current Max: 10 А
- Contact Voltage AC Nom: 220 В
- Contact Voltage DC Nom: 30 В
- Coil Resistance: 100 Ом
- Contacts: 3PDT
- Coil Type: DC
RR3BULDC12V, RR3B ULDC12V
