Линейка продуктов KEEN SIDE
Datasheet RU4S-C-A110 - IDEC Даташит POWER Реле, 4PDT, 110 VAC, 6 А, PLUG IN — Даташит
IDEC RU4S-C-A110
Наименование модели: RU4S-C-A110
23 предложений от 10 поставщиков
Реле Мощности, Electromechanical Relay 110/120VAC 4.55KΩ 6A 4PDT (( 27.5mm 21mm 41.6mm)) Socket General Purpose Relay
RU4S-C-A110
IDEC
731 ₽
RU4S-C-A110
IDEC
1 210 ₽
Эиком
RU4S-C-A110
IDEC
от 1 931 ₽
RU4S-C-A110
Производитель: IDEC
Описание: POWER Реле, 4PDT, 110 VAC, 6 А, PLUG IN
data sheetСкачать Data Sheet
RU Series RU Series -- General Purpose Relays
Key features of the RU series include: · Non-polarized LED indicator standard · Solder-free construction (spot welded, no solder points, lead-free) · No internal wires · Mechanical flag indicator standard · Manual latching lever with color coding for AC or DC coil · Available without latching lever (or with momentary check button) · Snap-on marking plate standard · Cadmium-free contacts - RoHS compliant · Color coded coils for visual distinction · Contact rating 6A: 4PDT 10A: DPDT
Relays
E
Contact Material
  • Тип реле: General Purpose
  • Coil Voltage VAC Nom: 110 В
  • Contact Current Max: 6 А
  • Contact Voltage AC Nom: 250 В
  • Contact Voltage DC Nom: 30 В
  • Coil Resistance: 4550 Ом
  • Contacts: 4PDT
  • Coil Type: AC
RU4SCA110, RU4S C A110
На английском языке: Datasheet RU4S-C-A110 - IDEC POWER RELAY, 4PDT, 110 VAC, 6 A, PLUG IN
