Datasheet RU4S-C-D24 - IDEC Даташит POWER Реле, 4PDT, 24 В DC, 6 А, PLUG IN — Даташит
IDEC RU4S-C-D24
Наименование модели: RU4S-C-D24
22 предложений от 9 поставщиков
Реле Мощности, Relay; ; 24VDC; 24VDC; 4PDT; 35mm H x 21mm W; UL recognized; c-UL; TOV; CE
RU4S-C-D24
IDEC
904 ₽
Эиком
RU4S-C-D24
IDEC
от 1 750 ₽
TradeElectronics
RU4S-C-D24
RU4S-C-D24
Производитель: IDEC
Описание: POWER Реле, 4PDT, 24 В DC, 6 А, PLUG IN
data sheetСкачать Data Sheet
RU Series RU Series -- General Purpose Relays
Key features of the RU series include: · Non-polarized LED indicator standard · Solder-free construction (spot welded, no solder points, lead-free) · No internal wires · Mechanical flag indicator standard · Manual latching lever with color coding for AC or DC coil · Available without latching lever (or with momentary check button) · Snap-on marking plate standard · Cadmium-free contacts - RoHS compliant · Color coded coils for visual distinction · Contact rating 6A: 4PDT 10A: DPDT
Relays
E
Contact Material
  • Тип реле: General Purpose
  • Coil Voltage VDC Nom: 24 В
  • Contact Current Max: 6 А
  • Contact Voltage AC Nom: 250 В
  • Contact Voltage DC Nom: 30 В
  • Coil Resistance: 605 Ом
  • Contacts: 4PDT
  • Coil Type: DC
RU4SCD24, RU4S C D24
На английском языке: Datasheet RU4S-C-D24 - IDEC POWER RELAY, 4PDT, 24 V DC, 6 A, PLUG IN
