Datasheet RU4S-D12 - IDEC Даташит POWER Реле, 4PDT, 12 В DC, 6 А, PLUG IN — Даташит
Наименование модели: RU4S-D12
![]() 18 предложений от 11 поставщиков Реле Мощности, Electromechanical Relay 12VDC 160Ω 6A 4PDT (( 27.5mm 21mm 41.6mm)) Socket General Purpose Relay | |||
RU4S-D12 IDEC | по запросу | ||
RU4S-D12 | по запросу | ||
Производитель: IDEC
Описание: POWER Реле, 4PDT, 12 В DC, 6 А, PLUG IN
RU Series RU Series -- General Purpose Relays
Key features of the RU series include: · Non-polarized LED indicator standard · Solder-free construction (spot welded, no solder points, lead-free) · No internal wires · Mechanical flag indicator standard · Manual latching lever with color coding for AC or DC coil · Available without latching lever (or with momentary check button) · Snap-on marking plate standard · Cadmium-free contacts - RoHS compliant · Color coded coils for visual distinction · Contact rating 6A: 4PDT 10A: DPDT
Relays
E
Contact Material
- Тип реле: General Purpose
- Coil Voltage VDC Nom: 12 В
- Contact Current Max: 6 А
- Contact Voltage AC Nom: 250 В
- Contact Voltage DC Nom: 30 В
- Coil Resistance: 160 Ом
- Contacts: 4PDT
- Coil Type: DC
RU4SD12, RU4S D12
