Datasheet RY2KS-UDC12V - IDEC Даташит POWER Реле, DPDT, 12 В DC, 3 А, PLUG IN — Даташит
IDEC RY2KS-UDC12V
Наименование модели: RY2KS-UDC12V
Реле Мощности, Electromechanical Relay DPDT 3A 12VDC 120Ω Socket
RY2KS-UDC12V
IDEC
1 409 ₽
RY2KS-UDC12V
IDEC
2 861 ₽
Элитан
RY2KS-UDC12V
IDEC
9 934 ₽
Производитель: IDEC
Описание: POWER Реле, DPDT, 12 В DC, 3 А, PLUG IN
data sheetСкачать Data Sheet
RY2KS Series Latch Relays
Self-maintained Latch Relays DPDT -- 3A contact capacity
The RY2KS series latch relays have a self-holding function using permanent magnets in the magnetic circuit.
Applying a voltage on the set (or reset) coil operates the armature and retains the contacts in that position until the opposite coil is energized, hence the latch relays are ideal for memory and flip-flop circuit applications. · Mountable in the same space as other miniature relays using the same sockets. · Recognized by UL and certified by CSA.
Types
Terminal Style Plug-in Terminal Basic With Check Button Type Type No. RY2KS-U RY2KS-UC Coil Voltage Code AC6, AC12, AC24, AC50, AC100, AC120 DC6, DC12, DC24, DC48, DC100, DC110
  • Тип реле: Latching
  • Coil Voltage VDC Nom: 12 В
  • Contact Current Max: 3 А
  • Contact Voltage AC Nom: 220 В
  • Contact Voltage DC Nom: 100 В
  • Coil Resistance: 120 Ом
  • Contacts: DPDT
  • Coil Type: DC
RY2KSUDC12V, RY2KS UDC12V
На английском языке: Datasheet RY2KS-UDC12V - IDEC POWER RELAY, DPDT, 12 V DC, 3 A, PLUG IN
