Datasheet RY2S-UTAC120V - IDEC Даташит POWER Реле, DPDT, 120 VAC, 3 А, PLUG IN — Даташит
Наименование модели: RY2S-UTAC120V
![]() Реле Мощности, Electromechanical Relay DPDT 3A 120VAC 8.1KΩ Bracket Mount | |||
RY2S-UTAC120V IDEC | 770 ₽ | ||
RY2S-UTAC120V IDEC | 4 667 ₽ | ||
RY2S-UTAC120V | по запросу |
Производитель: IDEC
Описание: POWER Реле, DPDT, 120 VAC, 3 А, PLUG IN
RY/RM Series
Relays
RY/RM Series -- General Purpose Miniature Relays
Key features of the RY series include: · Compact miniature size saves space · 2PDT and 4PDT models, available with bifurcated crossbar contacts, ensure reliable low-current switching for dry circuit applications · Choice of plug-in/solder or PCB type terminals · Options include check button for test operation and indicator lights · DIN rail, surface, panel, and PCB type sockets available for a wide range of mounting applications Contact Material Contact Resistance
RY2, RY4: Silver (Ag), gold-plated RY22, RY42: Ag-Pd alloy RM: Silver (Ag) RY2, RY4: 50m maximum RY22, RY42: 100m maximum RM: 30m maximum RY2, RY4: 5V DC, 10mA/24V DC, 5mA RM2: 24VDC/10mA, 5VDC/20mA (reference value) Bifurcated contacts: RY22, RY42: 1V DC, 100µA (reference value) 20ms maximum 20ms maximum 110% of the rated voltage File No.
B020813332452 80% of the rated voltage 30% or more of the rated voltage 10% or more of the rated voltage RY2, RY22: DC
- Тип реле: Miniature
- Coil Voltage VAC Nom: 120 В
- Contact Current Max: 3 А
- Contact Voltage AC Nom: 220 В
- Contact Voltage DC Nom: 30 В
- Coil Resistance: 7680 Ом
- Contacts: DPDT
- Coil Type: AC
RY2SUTAC120V, RY2S UTAC120V
