Datasheet RY4S-UAC110-120V - IDEC Даташит POWER Реле, 4PDT, 120 VAC, 5 А, PLUG IN — Даташит
IDEC RY4S-UAC110-120V
Наименование модели: RY4S-UAC110-120V
7 предложений от 7 поставщиков
Electromechanical Relay 110/120VAC 4.29KOhm 5A 4PDT(27.5x21x42)mm Socket Miniature Relay
RY4S-UAC110-120V
IDEC
575 ₽
RY4S-UAC110-120V
RY4SUAC110120V
МосЧип
RY4S-U-AC110-120V
Производитель: IDEC
Описание: POWER Реле, 4PDT, 120 VAC, 5 А, PLUG IN
data sheetСкачать Data Sheet
RY/RM Series
Relays
RY/RM Series -- General Purpose Miniature Relays
Key features of the RY series include: · Compact miniature size saves space · 2PDT and 4PDT models, available with bifurcated crossbar contacts, ensure reliable low-current switching for dry circuit applications · Choice of plug-in/solder or PCB type terminals · Options include check button for test operation and indicator lights · DIN rail, surface, panel, and PCB type sockets available for a wide range of mounting applications Contact Material Contact Resistance
RY2, RY4: Silver (Ag), gold-plated RY22, RY42: Ag-Pd alloy RM: Silver (Ag) RY2, RY4: 50m maximum RY22, RY42: 100m maximum RM: 30m maximum RY2, RY4: 5V DC, 10mA/24V DC, 5mA RM2: 24VDC/10mA, 5VDC/20mA (reference value) Bifurcated contacts: RY22, RY42: 1V DC, 100µA (reference value) 20ms maximum 20ms maximum 110% of the rated voltage File No.
B020813332452 80% of the rated voltage 30% or more of the rated voltage 10% or more of the rated voltage RY2, RY22: DC
  • Тип реле: Miniature
  • Coil Voltage VAC Nom: 120 В
  • Contact Current Max: 5 А
  • Contact Voltage AC Nom: 240 В
  • Contact Voltage DC Nom: 30 В
  • Coil Resistance: 4170 Ом
  • Contacts: 4PDT
  • Coil Type: AC
RY4SUAC110120V, RY4S UAC110 120V
На английском языке: Datasheet RY4S-UAC110-120V - IDEC POWER RELAY, 4PDT, 120 VAC, 5 A, PLUG IN
