Datasheet HY1A1230AC - IMO Precision Controls Даташит Реле, SPNO, 230 VAC — Даташит
IMO Precision Controls HY1A1230AC
Наименование модели: HY1A1230AC
Реле Мощности, RELAY, SPNO, 230VAC; Series: HY; Relay Type: General Purpose; Voltage, Coil AC Nom: 240V; Resistance, Coil: 208KΩ; ...
HY1A1230AC
1 251 ₽
Производитель: IMO Precision Controls
Описание: Реле, SPNO, 230 VAC
data sheetСкачать Data Sheet
High Capacity Relay HY
3mm contact gap as standard 30A high capacity relay able to withstand momentary voltage drops to 50% rated Class F insulation Heavy load up to 7500VA UL/cUL approved
Options and ordering codes
HY
Power Relay
  • Тип реле: General Purpose
  • Coil Voltage VAC Nom: 240 В
  • Contact Current Max: 30 А
  • Contact Voltage AC Nom: 250 В
  • Coil Resistance: 208 кОм
  • Contact Configuration: SPNO
  • Coil Type: AC Coil
  • Coil Current: 10.8 мА
  • Nom Operating Power: 2.7 VA
  • Relay Mounting: Plug-In
  • Внешняя длина / высота: 36 мм
  • Внешняя ширина: 51.5 мм
  • External Depth: 34.9 мм
  • SVHC: No SVHC (15-Dec-2010)
  • Contact Current AC Max: 30 А
  • Contact Voltage AC Max: 250 В
  • Mounting Type: PCB
  • Number of Poles: 1
  • Семейство: HY
  • Approval Bodies: CUR, TUV
  • Approval Category: VDE 0435
  • Switch Current Max: 30 А
  • Switching Power Max: 6600 VA
На английском языке: Datasheet HY1A1230AC - IMO Precision Controls RELAY, SPNO, 230 VAC
