Datasheet HY41PN12AC - IMO Precision Controls Даташит Реле, 4PCO, 12 VAC — Даташит
IMO Precision Controls HY41PN12AC
Наименование модели: HY41PN12AC
Производитель: IMO Precision Controls
Описание: Реле, 4PCO, 12 VAC
data sheetСкачать Data Sheet
Miniature General Purpose Relay HY
General purpose 5,7 amp Plug in Power Relay, available in 2PCO, 3PCO and 4PCO Arc barriers prevent flashover between contacts Manual operator for circuit testing with latch facility colour coded for AC/DC identification Mechanical flag indicator showing armature operation LED indicators showing coil energisation UL and cUL approvals
Options and ordering codes
HY
General purpose power relay 2 pole changeover 3 pole changeover 4 pole changeover 2 3 4 Plug in 1
  • Тип реле: General Purpose
  • Coil Voltage VAC Nom: 12 В
  • Contact Current Max: 5 А
  • Contact Voltage AC Nom: 250 В
  • Coil Resistance: 46 Ом
  • Contact Configuration: 4PCO
  • Coil Type: AC Coil
  • Coil Current: 100 мА
  • Nom Operating Power: 1.2 VA
  • Relay Mounting: Plug-In
  • Внешняя длина / высота: 35 мм
  • Внешняя ширина: 28 мм
  • External Depth: 21.5 мм
  • SVHC: No SVHC (15-Dec-2010)
  • Contact Current AC Max: 5 А
  • Contact Current DC Max: 5 А
  • Contact Voltage AC Max: 250 В
  • Contact Voltage DC Max: 30 В
  • Mounting Type: Plug-In
  • Number of Poles: 4
  • Семейство: HY
  • AC Coil Power: 1.2 VA
  • Approval Bodies: UL, VDE
  • Coil Operating Lower Percent Limit: 80%
  • Coil Operating Upper Percent Limit: 110%
  • Contact Material: Silver Nickel, Gold Flashed
  • Operating Time: 25 мс
  • Release Time: 25 мс
  • Switch Current Max: 5 А
    70°C
На английском языке: Datasheet HY41PN12AC - IMO Precision Controls RELAY, 4PCO, 12 VAC
