Компактное аудиорешение Nuvoton NSP2340BA24E
Datasheet HY42XX12DC - IMO Precision Controls Даташит Реле, 4PCO, 12 В DC — Даташит
IMO Precision Controls HY42XX12DC
Наименование модели: HY42XX12DC
Производитель: IMO Precision Controls
Описание: Реле, 4PCO, 12 В DC
data sheetСкачать Data Sheet
Miniature General Purpose Relay HY
General purpose 5,7 amp Plug in Power Relay, available in 2PCO, 3PCO and 4PCO Arc barriers prevent flashover between contacts Manual operator for circuit testing with latch facility colour coded for AC/DC identification Mechanical flag indicator showing armature operation LED indicators showing coil energisation UL and cUL approvals
Options and ordering codes
HY
General purpose power relay 2 pole changeover 3 pole changeover 4 pole changeover 2 3 4 Plug in 1
  • Тип реле: General Purpose
  • Coil Voltage VDC Nom: 12 В
  • Contact Current Max: 5 А
  • Contact Voltage AC Nom: 250 В
  • Coil Resistance: 160 Ом
  • Contact Configuration: 4PCO
  • Coil Type: DC Coil
  • Coil Current: 75 мА
  • Nom Operating Power: 900 мВт
  • Relay Mounting: PC Board
  • Внешняя длина / высота: 27.5 мм
  • Внешняя ширина: 21.54 мм
  • External Depth: 36 мм
  • SVHC: No SVHC (15-Dec-2010)
  • Contact Current AC Max: 5 А
  • Contact Current DC Max: 5 А
  • Contact Voltage AC Max: 250 В
  • Contact Voltage DC Max: 28 В
  • Mounting Type: Plug-In
  • Number of Poles: 4
  • Семейство: HY
  • AC Coil Power: 1.2 VA
  • Approval Bodies: UL, CSA
  • Coil Operating Lower Percent Limit: 80%
  • Coil Operating Upper Percent Limit: 110%
  • Contact Material: AgNi
  • DC Coil Power: 0.9 Вт
  • IP / NEMA Rating: IP40
  • Number of Electrical Operations: 100000
  • Number of Mechanical Operations: 20000000
  • Operating Time: 10 мс
  • Release Time: 10 мс
  • Switch Current Max: 5 А
  • Switching Current AC Max: 5 А
  • Switching Current DC Max: 5 А
    70°C
На английском языке: Datasheet HY42XX12DC - IMO Precision Controls RELAY, 4PCO, 12 V DC
Политика конфиденциальности
