Datasheet 785XBXC-120A - Magnecraft Даташит POWER Реле, DPDT, 120 VAC, 16 А, PLUG IN — Даташит
Magnecraft 785XBXC-120A
Наименование модели: 785XBXC-120A
Relay; E-Mech; Latching; DPDT; Cur-Rtg 16AAC/ADC; Ctrl-V 120AC; Vol-Rtg 277/28AC/DC
785XBXC-120A
LifeElectronics
785XBXC-120A
785XBXC-120A
Schneider Electric
Производитель: Magnecraft
Описание: POWER Реле, DPDT, 120 VAC, 16 А, PLUG IN
data sheetСкачать Data Sheet
Latching, Sequence and Impulse Relays ­ Application Data
Energy Conservation Relays In many applications it is important for the customer to conserve electrical energy.
One approach to energy conservation in an electrical system is to use relays that do not require constant power to maintain contact closure. "Latching relay" is a generic term that is used to describe a relay that maintains its contact position after the control power has been removed. Latching relays allow a customer to control a circuit by simply providing a single pulse to the relay control circuit. Latching relays are also desirable when the customer needs to have a relay that maintains its position during an interruption of power. There are three main types of Latching relays. Magnetic latching, Mechanical Latching and Impulse Sequencing. Magnetic Latching Relays Magnetic Latching relays require one pulse of coil power to move their contacts in one direction, and another, redirected pulse to move them back. Repeat
  • Тип реле: Latching
  • Coil Voltage VAC Nom: 120 В
  • Contact Current Max: 16 А
  • Contact Voltage AC Nom: 277 В
  • Contact Voltage DC Nom: 28 В
  • Coil Resistance: 10 кОм
  • Contacts: DPDT
  • Coil Type: AC
785XBXC120A, 785XBXC 120A
На английском языке: Datasheet 785XBXC-120A - Magnecraft POWER RELAY, DPDT, 120 VAC, 16 A, PLUG IN
