Datasheet 785XBXCD-12D - Magnecraft Даташит POWER Реле, DPDT, 12 В DC, 16 А, PLUG IN — Даташит
Наименование модели: 785XBXCD-12D
![]() Несгруппированные, SCHNEIDER ELECTRIC/MAGNECRAFT 785XBXCD-12D POWER RELAY, DPDT, 12VDC, 16A, PLUG IN | |||
785XBXCD-12D Magnecraft | 1 273 ₽ | ||
785XBXCD-12D Schneider Electric | 1 395 ₽ | ||
785XBXCD-12D | по запросу | ||
Производитель: Magnecraft
Описание: POWER Реле, DPDT, 12 В DC, 16 А, PLUG IN
Latching, Sequence and Impulse Relays Application Data
Energy Conservation Relays In many applications it is important for the customer to conserve electrical energy.
One approach to energy conservation in an electrical system is to use relays that do not require constant power to maintain contact closure. "Latching relay" is a generic term that is used to describe a relay that maintains its contact position after the control power has been removed. Latching relays allow a customer to control a circuit by simply providing a single pulse to the relay control circuit. Latching relays are also desirable when the customer needs to have a relay that maintains its position during an interruption of power. There are three main types of Latching relays. Magnetic latching, Mechanical Latching and Impulse Sequencing. Magnetic Latching Relays Magnetic Latching relays require one pulse of coil power to move their contacts in one direction, and another, redirected pulse to move them back. Repeat
- Тип реле: Latching
- Coil Voltage VDC Nom: 12 В
- Contact Current Max: 16 А
- Contact Voltage AC Nom: 277 В
- Contact Voltage DC Nom: 28 В
- Coil Resistance: 90 Ом
- Contacts: DPDT
- Coil Type: DC
785XBXCD12D, 785XBXCD 12D
