Datasheet W199AX-10 - Magnecraft Даташит POWER Реле, DPST-NO, 240 VAC, 40 А, PANEL — Даташит
Наименование модели: W199AX-10
Купить W199AX-10 на РадиоЛоцман.Цены — от 1 365 до 5 743 ₽7 предложений от 7 поставщиков , Electromechanical Relay 240VAC 1.2KΩ 40A DPST-NO (63.5x61.7x57.15)mm Power Relay | |||
| W199AX-10 Schneider Electric | 1 365 ₽ | ||
| W199AX-10 Schneider Electric | 2 820 ₽ | ||
| W199AX-10 | по запросу | ||
Производитель: Magnecraft
Описание: POWER Реле, DPST-NO, 240 VAC, 40 А, PANEL
Advantages of the W199 Power Relay
The Magnecraft 199 relay is the powerhouse open relay.
Standard parts can handle up to 40A and there are options to handle up to 50A. The device is available in a variety of configurations and coil voltages. Available with up to two poles, double and single throws, insulated and noninsulated double make and/or break, and several switching forms. Options include auxiliary 10A switches with quick connects or screw terminals, quick connects on the coils and/or contacts, tungsten stationary contacts, fine silver contacts, pressure wire connectors on the output terminals and blowout magnets near the contacts for high voltage DC switching.
Optional Cover (50-1289-1) See Section 3 p.22
Blowout Magnet for High DC Switching
W199ADBX-4 40Amp
- Тип реле: Power
- Coil Voltage VAC Nom: 240 В
- Contact Current Max: 40 А
- Contact Voltage AC Nom: 600 В
- Contact Voltage DC Nom: 28 В
- Coil Resistance: 1200 Ом
- Contacts: DPST-NO
- Coil Type: AC
W199AX10, W199AX 10
