Datasheet W199X-14 - Magnecraft Даташит POWER Реле, DPDT, 110 В DC, 40 А, PANEL — Даташит
Наименование модели: W199X-14
5 предложений от 5 поставщиков , Electromechanical Relay 110VDC 6KΩ 40A DPDT (63.5x79.2x58.67)mm Power Relay | |||
W199X-14 Schneider Electric | 1 472 ₽ | ||
W199X-14 | по запросу | ||
W199X-14 Schneider Electric | по запросу |
Производитель: Magnecraft
Описание: POWER Реле, DPDT, 110 В DC, 40 А, PANEL
Advantages of the W199 Power Relay
The Magnecraft 199 relay is the powerhouse open relay.
Standard parts can handle up to 40A and there are options to handle up to 50A. The device is available in a variety of configurations and coil voltages. Available with up to two poles, double and single throws, insulated and noninsulated double make and/or break, and several switching forms. Options include auxiliary 10A switches with quick connects or screw terminals, quick connects on the coils and/or contacts, tungsten stationary contacts, fine silver contacts, pressure wire connectors on the output terminals and blowout magnets near the contacts for high voltage DC switching.
Optional Cover (50-1289-1) See Section 3 p.22
Blowout Magnet for High DC Switching
W199ADBX-4 40Amp
- Тип реле: Power
- Coil Voltage VDC Nom: 110 В
- Contact Current Max: 40 А
- Contact Voltage AC Nom: 600 В
- Contact Voltage DC Nom: 28 В
- Coil Resistance: 6000 Ом
- Contacts: DPDT
- Coil Type: DC
W199X14, W199X 14
