Datasheet W9AS5A52-120 - Magnecraft Даташит POWER Реле, SPDT, 120 VAC, 30 А, FLANGE — Даташит
Magnecraft W9AS5A52-120
Наименование модели: W9AS5A52-120
5 предложений от 5 поставщиков
, Electromechanical Relay 120VAC 3KΩ 30A SPDT (50.29x27.4x27.9)mm Flange Miniature Relay
W9AS5A52-120
Schneider Electric
298 ₽
W9AS5A52-120
Schneider Electric
298 ₽
W9AS5A52-120
Schneider Electric
550 ₽
W9AS5A52-120
Производитель: Magnecraft
Описание: POWER Реле, SPDT, 120 VAC, 30 А, FLANGE
data sheetСкачать Data Sheet
W9A Miniature Power Relays/SPST and SPDT 30 Amp Rating (DC and AC)
Small Size Class F Insulation for max coil temperature of 155°C
Meets UL873 & UL508 Spacing (8mm through air, 9.5mm over surface)
Quick-Connect Terminals for simple connection
Flange Mounting
  • Тип реле: Miniature
  • Coil Voltage VAC Nom: 120 В
  • Contact Current Max: 30 А
  • Contact Voltage AC Nom: 240 В
  • Contact Voltage DC Nom: 28 В
  • Coil Resistance: 3000 Ом
  • Contacts: SPDT
  • Coil Type: AC
W9AS5A52120, W9AS5A52 120
На английском языке: Datasheet W9AS5A52-120 - Magnecraft POWER RELAY, SPDT, 120 VAC, 30 A, FLANGE
