Datasheet DILM32-10(400V50HZ,440V60HZ) - Moeller Даташит CONTACTOR, 15 кВт, WITH 1NO AUX — Даташит
Moeller DILM32-10(400V50HZ,440V60HZ)
Наименование модели: DILM32-10(400V50HZ,440V60HZ)
31 предложений от 20 поставщиков
Фронтальный блок вспомогательных контактов, 4 полюса 2НО+2НЗ, винтовые Зажимы
DILM32-XHI11
Moeller
521 ₽
Microfind
DILM32-XHI22
Eaton
от 1 471 ₽
DILM32-XHI11
от 3 154 ₽
TradeElectronics
DILM32-10-24VDC
Производитель: Moeller
Описание: CONTACTOR, 15 кВт, WITH 1NO AUX
data sheetСкачать Data Sheet
Type: DILM32-10(400V50HZ,440V60HZ) Article No.: 277262
Ordering information
Rated operational current AC-3 400 V Max.
rating for three-phase motors, 50 ­ 60 Hz AC-3 230 V Max. rating for three-phase motors, 50 ­ 60 Hz AC-3 400 V Max. rating for three-phase motors, 50 ­ 60 Hz AC-3 690 V Max. rating for three-phase motors, 50 ­ 60 Hz AC-4 230 V Max. rating for three-phase motors, 50 ­ 60 Hz AC-4 400 V Max. rating for three-phase motors, 50 ­ 60 Hz AC-4 690 V Ie P P P P P P A kW kW kW kW kW kW 32 10 15 17 4 7 10
General
Standards Lifespan, mechanical AC operated DC operated Operating frequency, mechanical AC operated DC operated Climatic proofing Ambient temperature Open Enclosed Storage °C °C °C -25/60 -25/40 -40/80 Operations/h Operations/h 5000 5000 Damp heat, constant, to IEC 60068-2-78 Damp heat, cyclical, to IEC 60068-2-30 Operations Operations Ч 106 Ч 106 10 10 IEC/EN 60947, VDE 0660, UL, CSA
  • Тип реле: Contactor
  • Contact Configuration: 1M
  • Внешняя длина / высота: 85 мм
  • Внешняя ширина: 45 мм
  • External Depth: 138 мм
  • SVHC: No SVHC (18-Jun-2010)
  • Number of Poles: 3
  • Approval Bodies: IEC/EN 60947, VDE0660, UL, CSA
  • Coil Frequency Max: 60 Гц
  • Coil Operating Frequency Min: 50 Гц
  • Coil Voltage Max: 440 VAC
  • Coil Voltage Min: 400 VAC
  • Dielectric Voltage Coil to Contact: 440 VAC
  • Dielectric Voltage Contact to Contact: 440 VAC
  • IP / NEMA Rating: IP00
  • Main Contact Current AC3 Max: 32 А
  • Power Rating: 15 кВт
DILM3210(400V50HZ,440V60HZ), DILM32 10(400V50HZ,440V60HZ), DILM32-10(400V50HZ440V60HZ), DILM32-10(400V50HZ 440V60HZ)
На английском языке: Datasheet DILM32-10(400V50HZ,440V60HZ) - Moeller CONTACTOR, 15 kW, WITH 1NO AUX
