Datasheet HRS4-S DC5V - Multicomp Даташит Реле, PCB, SPCO, 5 В DC — Даташит
Наименование модели: HRS4-S DC5V
PCB Power Relays | |||
HRS4-S-DC5V Multicomp | 175 ₽ | ||
HRS4-SDC5V | по запросу | ||
HRS4-S-DC5V | по запросу | ||
Производитель: Multicomp
Описание: Реле, PCB, SPCO, 5 В DC
HRS4 Series PCB Power Relays
Features:
· SPCO contacts.
· Sealed to allow washing after flow soldering.
Specifications:
Coil Data: Nominal Voltage Nominal Power Consumption Contact Data: Contact Arrangement Contact Material Contact Rating Maximum Switching Voltage Maximum Switching Current Maximum Switching Power Contact Resistance (Initial) Life Expectancy Electrical Mechanical General Data: Minimum Insulation Resistance Dielectric Strength Maximum Operate Time Maximum Release Time Operating Temperature Range Shock Resistance Vibration Resistance : 100M at 500V dc. : 750V ac, 1 minute between open contacts 1,500V ac, 1 minute between contacts and coil. : 8ms. : 5ms. : -30°C to +85°C. : 10G. : 10 - 55Hz , Amplitude 1.5mm. : 1 Form A , 1 Form C. : AgCdo. : 10A 120V ac/24V dc (1C). 15A 120V ac/24V dc (1A). : 110V dc/240V ac. : 15A. : 1800VA , 360W. : 50m at 6V dc 1A. : 100,000 operations at nominal load : 10,000,000 operations. : 3V dc to 48V dc. : 360 to 450 mW.
- Тип реле: Power
- Coil Voltage VDC Nom: 5 В
- Contact Current Max: 15 А
- Contact Voltage AC Nom: 120 В
- Contact Voltage DC Nom: 24 В
- Coil Resistance: 50 Ом
- Contact Configuration: SPCO
- Coil Type: DC Coil
- Nom Operating Power: 450 мВт
- Relay Mounting: PC Board
- Внешняя длина / высота: 15.8 мм
- Внешняя ширина: 15.5 мм
- External Depth: 19 мм
- Contact Current AC Max: 5 А
- Contact Current DC Max: 5 А
- Contact Voltage AC Max: 240 В
- Contact Voltage DC Max: 24 В
- Mounting Type: PCB
- Number of Poles: 1
- Семейство: HRS4
- Approval Bodies: UL
- DC Coil Power: 720 мВт
- Operating Time: 8 мс
- Release Time: 5 мс
- Switch Current Max: 15 А
- Рабочий диапазон температрур: -30°C ... 70°C
HRS4S DC5V, HRS4 S DC5V
